Rear Seal ( Neoprene VS Rope Type
HornetSpecial
Thanks, HornetSpecial
HornetSpecial wrote:
Walt here. To do the correct job go to Walt's tech book volume one to page 9. Or go to the WTN March-April 1996. Then go to volume two, page 11 or the WTN Nov-Dec 2005. There is no short cuts to this job and don't try packing the upper half for it will just leak worst. The correct way is a lot of work but results are better.
I have to replace rear seal in my 51 Hollywood, and have to do it while motor is in car. I have had this done for me in the past with not much luck. They leaked worse after I had them replaced. Which one works best, and any tips on replaceing would be helpful.
Thanks, HornetSpecial0 -
Thanks Walt!!I will consider your tech book. Maybe both books. One can never have enough Hudson knowledge,
Thanks Paul0
