Trim retainer needed
I have been searching for the stainless trim retainer for the piece just above the rear window. I am talking about the one for the ~4 ft long piece that goes between the s-shaped rear pillar molding. I have the trim, but KGAP told me they don't make the retainer. I also sent a sample about a year ago to Dellis Hudson and heard no response. Anyone had any better luck?
Rich
Attachment not found.
Rich
that one should be an easy find
the retainer is rarely deteriorated much and is the easiest trim piece to remove and reinstall on a Hudson.0 -
This place has so much stuff maybe you will find what you need. Good luck, Ron
http://www.restorationspecialties.com/0 -
Piece located. Thanks Hudzilla.0
rpmonroe wrote:that one should be an easy find
I actually have found that to be one of the more tougher trim prieces to get off the 54 hudsons due heavy rust from the retainers sitting horizontal0 -
On a 54 it is more difficult since the trim piece itself is narrower and fits tighter in general.
I guess it's only true for 52-530 -
ratlee2 wrote:
Walt here, I have one that is in perfect shape. no rust through and a light bead blast will have it looking new. If interested e-mail me at waltmordenti@aol.comI have been searching for the stainless trim retainer for the piece just above the rear window. I am talking about the one for the ~4 ft long piece that goes between the s-shaped rear pillar molding. I have the trim, but KGAP told me they don't make the retainer. I also sent a sample about a year ago to Dellis Hudson and heard no response. Anyone had any better luck?
Rich
Attachment not found.0
