36 Terraplane rear fender
Check with AL at the following site:
http://www.hudsoncarsandparts.com/
He has a 36 Hudson on the page that is For Sale0 -
My gut feeling is that very little sheet metal interchanges between the two years.
Here is a view of the '36 fender...
....and of the 1937. The wheel opening alone, is different.
In the Master Chassis Group Parts Book 1930-1939
Lists Rear Fender RHS Part No A120022
Rear Fender LHS Part No A120025
Fit 1937 Models 72 thru 77 Except 73 Bus Cpe0 -
My experience is that only 1936 Hudson or Terraplane fenders will fit a 1936 Terraplane. The 1937 was a completely redesigned car and although it looks deceptively like a '36, it is shorter and wider and almost nothing on the body interchanges. I may be incorrect, but I don't think so.0
HI just thought I would let you know this is my understanding I was told that only 1936 fenders will fit because it is a one year car only rear fenders are the same on Hudson an Terraplane but the( front ones )are different if you have a Hudson you need ones from a Hudson if you have a Terraplane you need ones from a Terraplane.0
Thanks for all the info. Does anyone have a 36 Terraplane drivers rear fender they can part with?0
Check with Tom Pett in Illinois, he is in the HET roster. He has a number of 1936 parts and probably has a fender for you. PM me if you need his number.0
