Update 3: The Hudson gets "re-styled"...
I've been thrashing on the Hudson lately, trying to get it ready for Billetproof. Alas, I'm not going to make it to Billetproof this year as I am getting called away for work (I'm a catastrophe claim adjuster) to the midwest.
SO, I thought I might put up a couple photos of the stuff I've been doing on the car.
So, this is what the car looked like about a month or so ago:
First things first, I had to strip the car to get it ready for DP sealer so I can do the finish bodywork. I wound up using a razor blade on the whole car. That pulled off most of the paint.
A bit more (a lot more) stripping produced a body in bare metal. There was a ton of bondo in the doors and rear quarters, almost a half inch thick in spots. Whoever had done the previous body work never even tried to pull the dents. There wasn't any rust under the bondo, so I lucked out.
I've wanted to do something with the grille opening for a long time. It was just kind of an unfinished hole in the front of the car. I had picked up a 51 Merc grille surround, and played around with a 51 Ford grille, a 53 Olds grille, a Kaiser grille bar, and finally decided to make my own surround and use a 51/52 Plymouth grille.
I used the Plymouth grille, narrowing it 4 inches. I also cut up the grille pan from the Plymouth and set it in place.
I took some 3" mandrel bent tubing for the top curve of the grille surround.
The stock Hudson hood has a big piece of trim that runs along the front edge, and I wasn't going to use it. I bent up some flat sheet at a buddy's house so I had a lip to work with and fashioned a new front edge. Filled some holes, and rounded the hood corners.
As of right now, the car is ready for DP. When I get back in mid July, I'll work on some custom fender flares for the rear wheel openings (I'm not using skirts) and get the thing painted.
I also removed the door handles and installed Lincoln pushbuttons.
Dude...that is so sweet! Nice work on that grill opening. I also was looking around for something different (i don't lke the '50 grill) and came up with the '55 Olds grill. Someone has since also used that, but I think I'll still try to see how it looks on mine.
Nice work and keep the pics coming. They're fantastic!0 -
Wow! Yer doin' nice work, man. Keep it up. You're gonna have a winner here. And keep the pics comming.0
Super Sharp! Love the grill and the Lincoln pushbuttons. My old man just picked up a '46 Lincoln, but he wouldn't let me rob the buttons;)!! Always look forward to seeing your pics.
THANKS!0 -
Love the grill. What color are you planning on?0
faustmb wrote:Love the grill. What color are you planning on?
It's going to be gloss black with bronze accents (wheels, 1/2 of the dash, garnish mouldings, column, steering wheel).0
- 118 Hudson 1916 - 1929
