running board matting
essexcoupe3131
Hi all , iam just starting to sort out gluing the matting that I got from k-Gap
onto my running boards and was going to use a heat resistant contact for this, is this appropiate to use or is ther something else
Iam interested in your thoughts
I dont know if this has been touched on or not
Thanks Mike
Thanks Mike
Don't really know if it's the BEST or not , but I used plain old DAP WELDWOOD contact glue lik you would use to put on counter tops and such from the hardware store. Got the mat in place and then beat the ??? out of it with a big rubber hammer . Year and a half and all is well. Bud0
thanks Bud, that was the theory I was going down, but had no exprience in this area, glues no problem as use it at my work , I was just thinking about what it does in the sun
Mike0 -
I echo using Dap Weldwood Glue available at Lowes, etc. I prefer the 'Gel' type...There has been no end to Dap Glue uses for restoration work. I even used it on the soles of my Nike's recently as a temporary fix and still holding after walking acres of swap meets....0 -
I know the product you are talking about , we dont have that brand here, but ados and bear have products with similar properties
Thanks0
