Having trouble putting Hudsoninte in your clutch?
I've seen long necked funnels in the automotive section of Wal Mart that work quite well - they're made to be used with todays cars that have a transmission fill down in the gloom somewhere.
Alex Burr
HudsonTech
Memphis, TN0 -
back at the beginning of my years of hudsoning, Hudsondad made a great fixture, that consists of a hose, a funnel, and a drilled out clutch plug, threaded to a fitting at the end of the hose, that once you remove the filler plug, you can easily thread the assembly into the flywheel. It works great, and is easy to use. I have used it many times, and never had a problem.0
