PAULARGETYPE, please check your PM's...
bump......0
Hudsonkid
I Saw It Woops On My Part I've Sent A Letter To Ron And I Will Be Fixing The Problem Do You Need The Bigger Size?0 -
Paul, I sent you a PM a few days ago and have the same problem with the two kits I bought.0
Paul, if I oculd get a pair of pumps, that would be great, I unsderstand that you are mainly a distributor in this, and appreciate you helping out. My old pumps were fine, and I just reused them. I will gladly send back the incorrect pumps, if they would be able to use them, just let me know...
The hudson is running, and the carbs seem great, otherwise! NO LEAKS!! let's knock on wood! seems the gaskets were of way superior quality.0
