Brake Light & Aux. Circuit Breaker
Where is the Aux. Circuit Breaker?
Is it in the bunch of wires above my steering column and behind my guages?
I am trying to track down the OEM brake switch wire that was by passed when the old aftermarket turn signal unit was installed.
Line 27 from the Wiring Diagram - Stop Light Switch Feed, 16 gauage, green.
I have Line 28, Stop Lamp ready from the trunk into the passenger cabin.
Pacemaker500 wrote:Where is the Aux. Circuit Breaker?
look on the topside of channel from the firewall to the steering column. if you know what the circuit breaker on the back of the light switch looks like it is the same. its about 1 1/2" by 3/4" x 3/4" with two studs for the wiring on top. pretty much all the wiring will lead you back to it or the light switch0 -
Thanks, Nick.
You do mean under the dash, correct? I ask because there is a fused box on the firewall in the engine bay that is NOT on the diagram.0 -
Pacemaker500 wrote:Thanks, Nick.
The fused box on the firewall must be the overdrive relay.0 -
Billy K.TN. wrote:The fused box on the firewall must be the overdrive relay.
That would make sense as I do have overdrive. Hudson could have put it in the diagram with a caveat "For those that have one."
Thanks.0
