Looking for more 40 parts---Steering components! Everything!!!
I need everything from the gearbox to the outer tie-rods for my 40! I just found out that 1950 upper and lower a-arms fit and I just mounted those. Anyone have a 40 parts car they are willing to dissmantle. I am in the need of other parts as well. I'll take a column as well
You might check with Al Saffrahn in AZ. He's got a lot of parts cars, and is a reliable supplier. Phone 520 568-2911.0
It's been five or six years since I've been to Windy Hills Auto Parts (in central Minnesota), but they had a then recently acquired forty at that time.
http://www.windyhillautoparts.com0 -
Don't get too picky. All the chassis parts in the front end from 40 to 47 will fit.0
Kind of figured but wasnt sure! Really I guess the major item would be the steering knuckle that bolts into the front crossmember as well as the bolt that holds it0
Some of the bolts rode in a pair of needle bearings, but nobody greased em so they're mostly trashed. I got a new kit from somebody..seems like Randy Maas. Somebody is making kits with oilite sleeve bearings also. Check your WTN0
I checked the 50 front end that I have and yes it has the upper and lower needle bearing sets but on the 40 I dont think it had any bearings.
The cast housing in the cross-member has a 1/2 inch on the top and bottom and the steering knuckle rested in between, my guess is maybe there was a zert fitting and just greased0 -
Yup, my 40 didn't have needle bearings either, but was nice and tight so I greased it up and re-used it.0
