49 Commodore Steering Box Seals?
rambos_ride
The output shaft that the pitman arm connects to looks to be leaking grease around the seal.
I have not torn the unit down - but does anyone know of rebuild kits for the steering box and/or a replacement seals for this application - or maybe even a rebuilt unit?
Thanks in advance!
Thanks in advance!
Have them on our website at 21stcenturyhudson.net for $25.00 for the kit/seal set.
we also are rebuilding carbs for all stepdown hudson's
russ maas @309-838-55510 -
I have went through a couple steering gears in the past. You should be able to get the bearings and seal at a good Bearing and Seal House (store). Just hope that the bearings on the worm gear are in good shape. Norm0
- 118 Hudson 1916 - 1929
