Front Brake Hose
Wagner #24070 Norm0
Thanks, The correct Wagner number is F24070. The new napa number is 36794.
As usual the forum comes through.0 -
hdsn49 wrote:Thanks, The correct Wagner number is F24070. The new napa number is 36794.
Also H19015 is the number at Advance Auto Parts. Bendix and others use this number also.
Jim Spencer0 -
Are these numbers the same for the front brake hoses on a 51 Hornet?0
51hornetA wrote:
You are correct.Are these numbers the same for the front brake hoses on a 51 Hornet?0 -
Hudzilla wrote:You are correct.
49 - 54 (Except Jet)
Jim0 -
Jim-'48 to '54 Norm0
Thanks everyone. Anyone have the Napa part number for wheel cylinders for a 51 Hornet?0
Left front wheel cylinder 18290 right front wheel cylinder 1891 those are wagner numbers running at $13 each at NAPA I paid $1o each at schucks.0
Right Front- WC 40952. Left Front- WC 40951
Right Rear- WC 59241. Left Rear- WC 59240.
These are Wagner #s. On the rear cyl.s the steel brake line screws directly into the cyls. (No adapter fitting like the origional Hudson cyls.) Norm0 -
Thanks for the info0
are these actual wheel cylinders???
that seems cheap for an extra set...
for the price of a rebuild kit, why even bother?0 -
herm wrote:Jim-'48 to '54 Norm
Norm, you are correct. My bad. Actually I knew that' somehow I blew it.
JIm0
