Speedometer worm gear
As you may know, Al Saffrahn in Arizona rebuilds overdrive (and maybe other) Hudson transmissions and you might want to address that question to him. He's listed in the H-E-T roster.0
YOU PROBLY DONT NEED THE WORM GEAR IN TRNS BUT THE DRIVE GEAR THAT GOES ON THE END OF SPEEDO CABLE, AM I CORRECTss?? BILL ALBRIGHT0
If it's the speedo pinion you need and not the worm gear on the tranny shaft, the Stewart Warner number on the gear is 104853 (10 teeth).0
Your correct Bill and thanks Park.0
- 118 Hudson 1916 - 1929
