53 wasp hydra
No Hudson did not make these trannys they were GM Hydramatics the same as in the Olds and Cadillacs. Some shops can fix them. HET member Gus Souza can fix it for you quite reasonably he is in the roster. You can get the kits here http://www.autotran.us/hmparts1.html0
