first of many questions.....
and until i can get a number of chances to really inspect step-down coupe
there will be many many many many more!
i've trolled through many hundreds of pages of posts, here on the board, and
here are a few questions i've come up with;
1: what sizes did our rims come in? (15 x 6, 3-1/2back space, like that)
2: what is the hub pattern? (5 by 4-1/4,4-1/2,4-3/4?)
3: where is the master cylinder mounted? (firewall, under the vehicle?)
4: who has a 700R4 on their 308? (i'd like to talk to them about feel and performance)
5: what is the hub to hub width of the rear axles in the 48-54 coupes? (are there different widths?)
ok, theres my start. i appriciate any time and info you can spare!
~kevin deez
~kevin deez
Welcome to the board!
I'll field the easy question - the master cylinder is mounted under the drivers side floor. I'm sure others will be by soon with the good answers to the other questions.0 -
50 3/8" inside backing plate to inside backing plate, and 56 3/4" wheel mounting surface to wheel mounting surface (give or take a small amount).0
The Master Cylinder is mounted on the front subframe beneath the drivers feet.0
rambos_ride wrote:
except 54 with power brakes, then it is firewall mounted.The Master Cylinder is mounted on the front subframe beneath the drivers feet.0 -
nick s wrote:except 54 with power brakes, then it is firewall mounted.
They made stepdowns after 49?
- You got me! 0 -
ok! thanx thanx thanx, 4 questions down and 1 to go.
any idea of back spacing on those rims '308?
now i just need to locate someone whos using the 700r4.
thanx for all your help thus far everyone!0 -
Kevin you want to talk transmissions and Hudson performance Gus Souza is your man. He's in the Chicago-Milwaukee Chapter0
thanx aaron, is he on the board here or do i hafta track him down via
email?
~kevind0 -
I believe Lloyd Miller has done this too (trans). I don't have his number as my club roster isn't with me, but he is in the CIC (California Inland Chapter). If your in the HET club you can look him up in the roster. If you aren't in the club JOIN! Good Luck!0
