Choke tubes
You might try a speed shop for an insulated, woven material (similar to aspbestos, which is probably what they used to begin with). I have something like that on my 1937 automatic choke heat tube but doggone if I recall where I got it!0
The parts stores probably still sell choke tube repair kits that have a replacement type of insulation. Doesn't look the same but they can't sell the old asbestos anymore.0
Jim G wrote:Does anyone know of a source for the fabric covering the choke tubes on twin-H carbs?
Jim G
Reedley, CA
Jim,
The closest I've been able to find is from JC Whitney. It's slightly larger diameter, and certainly a different stiffness material compared to the original stuff, but when it's in place with a 'hog ring' to hold it to the tube, it looks pretty darn close to the original.
http://www.jcwhitney.com/autoparts/Search?catalogId=10101&storeId=10101&sku=wb142983r
Good Luck0
