Lock washer application guide
I picked this up on the Studebaker Drivers Club forum and thought it worthwhile to pass along. The site linked below has an application guide so you can know why a certain type of lock washer, external tooth, internal tooth, split, etc. etc. is used. As I am working on my '50 I am trying to replace the lock washers with the same type as the factory and often wondered why so many toothed washers were used under the hood.
http://www.wclco.com/Lock_Washers/
JUST FOR EVERY ONES INFO THE Toothed Lock Washers ARE ONE TIME USE ONLY WHEN YOU LOOSEN ONE IT LOOSES IT'S LOCKING ABILITY TO LOCK SO WHEN REBUILDING SAY A HUDSON REAR END WHERE THE RING GEAR IS HELD ON WITH SPECAL BOLTS AND Toothed Lock Washers AND A NUT BE SURE YOU USE NEW LOCKS !!!
HUDSOONLY
PAULARGETYPE0
