Removing Step down rear axle
I would like to replace the inner rear axle seals on my 50P. The shop manual shows a big slide hammer used to remove the axels themselves.
Not owning a large slide hammer, it there a DIY trick or tool I can safely use to do this? Anything else I should be aware of?
Thanks in advance,
Matt
Thanks in advance,
Matt
MATT
yes just take your brake drum and remove the key and put it back on the axel with the nut just on till your sure you won't pull out the threads now use the drum as a slide puller it works every time
Hudsonly
PAULARGETYPE0 -
Thats the kind of simple answer I was hoping for.
Thanks Paul,
Matt0 -
Another simple way is to use a length of chain about 2 or three feet long. Screw one end of the chain on to the axle nut, and the other end around a sledge hammer. Swing the hammer outwards, and the intertia will pull the axle out.
Geoff.0 -
you can easily build a puller. this method is safer (as you aren't dealing with the inirtia when something slips) and gentler on the bearings also in a tight garage, getting room to make your swing may not be easy.
use a piece of bar stock put three holes in it the center one fot the threaded portion of the axle, and one to each end for jack bolts. attach to the axle with the axle nut put bolts through the other holes with nuts between the bar and the housing. hold the bolt head and tighten the nuts to draw out the bearing. be sure to have enough working room in the threads or the thickness of the outer race (3/4" or so) long fully threaded bolts are ideal, but you can always shim if necessary.0 -
An old flywheel works great.0
I used the first method suggested by Paul, it worked fine. As soon as I thought it wasn't working, the shaft popped out.
I think I'll try to score an old flywheel for next time.
Thanks for all the great advice,
Matt0
- 118 Hudson 1916 - 1929
