Lifetime supply?
And some. How many times do you change your fluid.??????????
I have a 20 litre drum here in my garage of what we used here in Australia many years ago, it was produced by Golden Fleece and called "Hudsonite Clutch" and I also have a pint tin still by Golden Fleece called "Hudesk Clutch.
Les P. Down Under.0 -
SamJ wrote:
But would it still be good to use? However, owning a piece of OEM history is cool.0 -
I certainly would not use it, as Automatic Transmission fluid is readily available
from the local servo or parts store.
but as you say good piece of history to keep with all my other HET goodies.0
