48 - 50 fenders wanted
I was in an accident last night and need a passenger fender but will take both sides and hood if the price is right. would like an arizona fender ( so i can pick it up) but will take anything at this point. email me with pics and prices or call me 623-206-2987 if you have any leads.
heres the pics
Im cyrus by the way
heres the pics
Im cyrus by the way
Ouch! Looks like you'll need some right side suspension parts too = at least a spindle and upper control arm...
Hows your door to fender gap on the drivers side? If its tight or hitting it may have shoved the subframe over a bit...
How's the cow that you hit?
Cyrus,
My condolences. Do you have Al Saffrahn's number? He's in Arizona, I believe, and has a bunch of Hudson parts. He's in the HET roster, or maybe someone else can chime in with his contact info (mine's not here, right now)
Good Luck,
Doug0 -
i not only need suspesion parts
but the farme 2... look at he first pic.. the right frame horn is pushed down 2 and over like an inch and a half.
the lower arm is bent clockwise, the spindale and knuckle is bent, the crossmember is bent and the upper a arm is bent in and down.
I have track most of the parts down except the upper and lower fender. iused to have mr. saffrah's number but cant find it. hopeing one of the hudson guys here might have it, or could give him a call to give him mine.0 -
49hudson wrote:i not only need suspesion parts
Do you have access to a frame machine? It might be more cost efficient to buy a complete front clip from someone0 -
i do work at autobody solutions in peoria....
but the lady that hit me was the one that got cited for the accident and has insurance (thank god). So im gonna try for the easy solution...... fat man front clip. even if I did straighten the frame, suspension parts are rare to find in good condition. plus it screwed up my steering components and the damn idler arm and idler arm joint0 -
I guess you kept your foot in it! Here's the info your seeking.
Al Saffrahn
Maricopa, AZ
520-568-29110 -
thanx dave....
I allways keep my foot in it.... and the wheel almost fell off....0
- 118 Hudson 1916 - 1929
