39 to 40 bumper interchange
Well, if I knew whether the 39 112 and Country clubs were the same, I could help ya, since I have a 39CC and a 40 Victoria in the woods.0
The distance between the 2 holes on the bumper for the bumper brackets (which are bolted to the frame) is 13.5" C-C. The distance between the inner bolt holes on the bumper itself is 26.75" C-C. Hope this info helps.
Kevin0 -
My measurements of the bumper on my 40 show a length of 5'8" tip to tip following the outer contour of the bumper. It is 4.5" in width. The outer bolt hole is 6.5" from the tip (end) and the hole with the bumper guard is 18" from the tip. Looking at Butler's book it appears that the 39 Country Club has either a recessed area for the license plate or a license plate bracket that is bolted to the bumper. Mine has neither.0
