Twin H in a Pacemaker
I am planning to put Twin H into my 50 Pacemaker. I have the intake, carbs, and filters, but no linkage or mounting brackets.
I'm looking for advice and /or photos of the linkage, mounting brackets etc.
Any information would be greatly appreciated,
Matt
Matt
I believe Bill Albright has mentioned he has several sets. Also, If you find the main long rod that mounts to the head, the rest can be made easy enough.0
Are you planning on putting the Twin H on a 232 ?0
Matt:
I have some information on my website.
Linkage picture from Parts book is here:
http://members.aol.com/stepdown53/images/TwinHlinkage.jpeg
Actual linkage picture:
http://members.aol.com/sanjuana/Images/TwinHLinkage.jpg
How to adjust the carbs bulletin here:
http://members.aol.com/stepdown53/TWINHADJUSTMENT10001.htm
How to Balance the carbs using a UNISYNC
http://members.aol.com/sanjuana/Incoming/UniSync.pdf
Picture of a Twin H maniford and carbs off car
http://members.aol.com/sanjuana/Images/TWINH.jpg
Pictures of Large Paul's Baby installation of a Hornet equipped with Twin H. The pictures show how Paul modified the rear aircleaner to allow the vacume wiper motor clearance. Great job... also pictures of installed and not installed components.
Good Luck Matt...0 -
Aaron D. IL wrote:Are you planning on putting the Twin H on a 232 ?
Acutally... yes, for now. The 232 runs strong overall. I have a 54 308 but it needs a total rebuild. Eventually, I plan to install it.
Ken,
Thanks for the info. I will check it out ASAP,
Matt0 -
Well I put a double barrel from intake and carb from the bigger Hudson engines and it did give the 232 a lot more pep....however I think one thing that would've helped in my experience with increasing the breathing is also increasing the exhaust. It tended to run a little rougher. I don't know what the 232 will do with a twin H on it though0
Putting a 308 Twin H set up on a stock 232 will work, but you will find that it will run fat or rich. It will look good but your driveability may suffer, but eye candy is cool!0
