262 or 308 ?
I believe there is a rib in the block, running front to back, just an inch or so above the oil pan flange, on the 308 but not the 262. I'm sure someone will correct me if I'm wrong, but gently, as is the custom on this board ;>)0
I don't know about other years/models, but the block in my '53 Hornet sedan has a very clear '308' stamped right on top, near the front.0
dak, are you referriing to the raised numbers in the head? i have not seen the blocks actually identified. any wideblock head (232 262 308) will bolt-up to any wide block and either narrow block (232 262) will bolt to either narrow head so this is not a good identifying mark. on a engine just laying around moving up or down is possible just to seal things up, but for a running engine, the intended or next head down (e.g. 262 on a 308 for higher compression) is highly likely as i doubt anyone would intentionally drop the compression. mike is correct about the extra rib on the 308, i don't believe you can discern a 232 from a 262 without measuring the stroke though. other than serial number but there are exceptions as wasps could have either number and i am not sure that all years have the model prefix in the motor serial number.0
308's have a stiffening rib near the bottom, as pointed out.
Alex B0 -
nick s wrote:dak, are you referriing to the raised numbers in the head? i have not seen the blocks actually identified. any wideblock head (232 262 308) will bolt-up to any wide block and either narrow block (232 262) will bolt to either narrow head so this is not a good identifying mark.
I stand corrected0 -
On both sides by the way.0
Mike (WA) wrote:I believe there is a rib in the block, running front to back, just an inch or so above the oil pan flange, on the 308 but not the 262. I'm sure someone will correct me if I'm wrong, but gently, as is the custom on this board ;>)
Mike is right... see the picture... 308s have the rib... others do not.0 -
Yes, the phrase "Ribbed for Pleasure!" comes to mind!
I use two other features to tell which series the big sixes
are, narrow block 48-50 series #1, wide block 51-54 series
#2 & 55-56 AMC series #3.
The picture above also a extra dipstick boss that is below
the distributor and to the right about 3" and just above
the oil pan rail that was used on the series 3 55 & 56 AMC
bodied Hudsons.
There is also a number pad in the head gasket surface
that is above & to the left of the oil fill tube that I have
been told that only the 55 & 56's used. I am not totally
sure about this point because I have seen some other
Hudson engines with this pad.
The dip stick pad can be used to date, at least as a series #3
Hudson 308. I find this better than looking for 1/2" head
studs or bolts as a lot of the series #2 have been converted.
My personal preference is the series #3 because of the superior
neoprene crankshaft main seals, larger 1/2 head bolts and
larger crankshaft flywheel bolts.
PaceRacer500 -
PaceRacer50 and Hudson 308,
Can either of you decipher the following numbers?
Pad # 5321096
Casting # 5325000
Thanks!0 -
as i look at the pic my block looks just like this one it has the same marks under the starter and in front of the block also if thr rib is the casting marks that stick out on the bottom of the block0
with the pic on this from where is the rib also just to make sure im looking at the right thing0
madhornet wrote:
the "rib" runs front to rear, i tried to highlight itwith the pic on this from where is the rib also just to make sure im looking at the right thing0 -
Hudson 308, You're right, the casting number is indeed the same as the one in the photo. Thanks for the heads up on where the casting date is located as well as your assistance.0
- 118 Hudson 1916 - 1929
