Tie rod ends
According to my Interchange Manual, '38 to '47 Hudson interchanges with '49 to '51 Lincoln and '49 to '51 and '54 Mercury. If that is the case, then the NAPA numbers are as follows:
Tie Rod End-Inner RPC 25586
Tie Rod End-Outer RPC 25253
To see a picture go here:
http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=430&CatId=7&SubCatId=10 -
Upon further review, the '49 to '51 Lincoln and '49 to '51 and '54 Mercury tie rod number is only for the left hand tie rod. For both sides use '48 to '54 Ford 1/2-3/4 ton truck tie rods. NAPA numbers are as follows:
Tie Rod End-Left NCP 2692240 or RCP 26353
Tie Rod End-Right NCP 2692241 or RCP 26408
Tie Rod End 36 Thru Stepdown
Auto Star ASES140R R outer, L inner
Also Moog, Mq ES140R or SPI 401-1005
Tie Rod End
Auto Star ASES62L L outer, R inner
Also Moog,Mq S62L or TRW ES324R
Got these from my independent jobber0
