Stabilizer Link Kit
5433HET wrote:Does anyone have a modern part# interchange for the stepdown stablizer link kits? One that could be obtained locally, such as NAPA? Thanks, Scott
Scott,
Don't know the NAPA number, but if you can, I'd suggest you call Dale Cooper. You'll probably have your parts within a few days. Plus, you'll be certain they're right, and for a good price.0 -
hudsonguy wrote:Scott,
This is a good opportunity to go with urethane. Will improve the handling and will last forever. K-Gap has them or you can match yours up with the Energy Suspension catalog like I did for my 54. If you want I can pull the numbers when I am home. I believe the bar is 3/4 so all you need is a set of generic 3/4 diameter center bushings and I think I got the 7 1/2 inch end link kit from them. Comes with new bolts washers and bushings. I think the whole deal was around 30.00.0 -
464Saloon wrote:This is a good opportunity to go with urethane. Will improve the handling and will last forever. K-Gap has them or you can match yours up with the Energy Suspension catalog like I did for my 54. If you want I can pull the numbers when I am home. I believe the bar is 3/4 so all you need is a set of generic 3/4 diameter center bushings and I think I got the 7 1/2 inch end link kit from them. Comes with new bolts washers and bushings. I think the whole deal was around 30.00.
Thanks for all the info. I ordered the link kit from Dale, but would like to replace the rubber cushions with urethane if you can tell me what I need to do that. Scott0 -
For stabalizer links for stepdowns chaeck out 78 up GM Malibus ,Regals, Grand Prix, Cutlass Supreme rear wheel drive link kits I believe the spacer bushing are the correct length. Available at local parts suppliers
Jim Spencer0
