29 Essex Pan gasket
Unknown
Does anyone know where I can buy a pan gasket also front and rear main bearing oil seals for my 29 Essex? It hasn't been run in four years and is leaking oil at every seam. LOL
Thanks
Blackie
  • Jon B
    Jon B Administrator
    Have you tried Dale Cooper? (He advertises in the WTN)
  • http://www.olsonsgaskets.com/inquiry.html
    There are some great people here. I got my 29 Hudson gaskets for them. Thanks Ron
  • EssexAdv
    EssexAdv Expert Adviser, Member
    Dale Cooper sell the same gaskets at the same price as does Olson's. Why not give the business to a Hudson guy to say thanks for helping!
    http://www.hudsonmotorcarco.com/
  • EssexAdv
    P.S. ther is no real main seal on a 29 Essex,. There is a slinger on the back of the crank. The oil is slung into a set of sheet metal peices with a cork gasket which seals it agains the block. The front is sealed by a felt timing case seal. Other than that these is some rope seal whcih seals the main caps to the block...not the crank
