212 fuel pump
I guess no one knows if you need a spacer block or not>0
Yes, definitely a spacer! Contact Dave Kostansek (sells rebuilt Hudson fuel pumps, advertises in WTN); he may be ablet to tell you how thing, might possibly have one, and definitely can sell you a rebuilt pump!0
Boozer
Yes you need a spacer. My 212 engine in my 37 requires a .275 inch spacer to get the right pump stroke i hope this helps.
Chuck G.0 -
Thanks There wasn't one on my 40 guess thta's why the person put on a 6 volt pump.0
One more question. Is the 308 Hornet fuel pump spacer the same size as the 212 fuel pump spacer? I have one for a 308 and was wondering if i could use it on the 212.0
Here is a thread that talks about how figure out how thick the spacer should be.
http://www.classiccar.com/forums/showthread.php?t=5752&highlight=fuel+pump0 -
Boozer
The mech. procedure manual says the spacer is 275 thou. thick or about 5 gaskets thick, hope this will help. Just do a little measuring.
Chuck G.0
