Axle and OD seals (Stepdown)
Howdy all ,
My 50 super has blown 5 seals recently and I’d like to get a double check on the axle seals and get a number for the OD rear seal .
I have inner seal as 40769s and outer as 17243 , are these proper ?
The transmission is of the single lever variant, I believe a R10 OD. Anyone have that seal number?
Thanks!
Outer rear seal can be one of the following:
Inner rear seal can be one of the following:
I am sure there are more. Inner seals are much harder to find.
@cchancel Thank you ! That part number is a pain to find!
it seems to me that my inners have royally failed and the new outers have failed as well .
I have had no problems locating the SKF 17310s for the outer. You will have to ask around to find the inner seals (maybe Wildrick will have something, https://www.wrphet.com/).
@cchancel Nor have I , I have two that will be in in the morning .
I’ll see about the others when I get the aforementioned two tomorrow
I’ll do that if I can’t find them !
thanks !
I have a pair of inners , new metric 70 x 35x 7 mm seals (2..756' x 1.375" x 0.280") $32 + $8 shipping in the USA. Kenneth Ufheil knnu21@yahoo.com, text: (469) 750-6691 (hearing impaired)
Anyone have any info on the OD unit pinion seal?
also any suggestions on solenoid resealing ?
- 118 Hudson 1916 - 1929
