Wheel Size for 1923 Hudson Sedan
That is the correct size for the 1923 model Hudson.0
Thanks GeoffNow if only I can find a front and rear hubs to make up some spares.Robert0
I may be able to help you. Will let you know. Do you just need the centres?0
The first time I saw a 1923 wheel I thought wow, they are like wagon wheels, very tall.0
rhurst
I have some parts left over from a 1922 Hudson I parted out but not sure if the wheels are the same as yours.
John
Those look like they would work.
What are you wanting to sell and what is the price.
Looks like you have two rear hubs, no front hub and 4 rims?
Do I have that right?
Robert
Robert
I have the 2 rear wheels with rims on them that are on the rear axle.
I also have the outer part of one front wheel ( the fellow) with a rim mounted on it. I also have two rims and a lock ring.
So a total of 5 outer rims,
2 rear wheels
1 fellow off a front wheel
4 lock rings
and I have enough Firestone rim locks and bolts for 2 wheels
$ 350 what I have mentioned
plus shipping and creating if I need to ship them to you
or you can pick up in person in Salisbury NC
thanks
John
Thanks John,
What I really need is one rear and one front hub. I'm afraid that after I remove the rust from the rims I might not be able to use them. Contacting Coker tire for new rims if they make them in my size. I know you don't want to part with the hubs as someone may want the whole axle. If you come across the hubs by themselves please contact me.
Robert
- 184 The Flathead Forum
