Connecting a ground strap to engine / body
NO-OX-ID Electrical Contact Grease- Conductive Lubricant | Sanchem, Inc.
Amazon.com: NO-OX-ID A-Special- Electrical Contact Grease- Keeps Metals Free of Rust and Corrosion- Part# 10203 : Industrial & Scientific
I've got no bones in the game, so to speak... but I can't speak ill for what I've used it for. $6 will probably last the rest of your life... My little sample tube will likely outlast me...0 -
CRC 2-26 electrical lubricant and cleaner
I finally found some "Noalox Anti-oxidant Compound" at Home Depot, available in either a paste (the consistency of grease), or liquid. It acts to seal ground connections from corrosion, while allowing electricity to pass through it without resistance.
In my case, I think my problem (sluggish starter motor) was due to bad grounding that had gotten worse over the years. After carefully examining and rejuvenating the engine's ground connection points (something I have not attended to for many years), I was delighted when the starter turned the engine over quite speedily, when I pressed the starter button.
On the other hand, "di-electric grease" is a viscous non-conductive waterproof substance used to protect electrical connections. You would want that for "hot" connections, where you don't want the electricity spilling out all over the place. When grounding, however, you want to pass around the ground to all adjacent body and drive train metal.0 -
Sorry to disagree Jon, but electricity does not "spill out in all directions". Quite the reverse, it will stop conducting readily when resistance is introduced, such as corrosion caused by salt, dirt, or moisture etc. Di-electric grease is used after a good clean connection has been made, to stop the incursion of such contaminants, whether to ground or voltage connections.0
A very skilled old car mechanic recommended Deoxit to me & I use it on all my electrical connections & grounds. Definitely sand off the contact points to bare metal, very important to do. Make sure you’re using very large battery cables if 6 volts still. Hope she keeps spinning well!0
- 118 Hudson 1916 - 1929
