Removing doors on 2 door pacemaker
The slide piece in the center is jut to limit how far the door can open.0
Those screws aren't always easy to unscrew. The threads can rust on the back side,
Use a spray rust buster to soak them down.
A hand impact screw driver is a good idea.
support the door in a balanced place with a floor jack.
A car from Ohio usually requires drilling out a few of the rusted screws0 -
You have to grind the top off the rivet that holds the limit bar. I have found the best method of removing the hinge screws is to get a large Philips head bit with a half-inch drive that fits in your socket set bar. This enables you to hold the pressure on whilst unscrewing with the bar. Better than an impact wrench which tends to chew out the internal faces of the screws.0
As lostmind points out, the screws that mount the hinges are difficult to remove. They pass through the hinge and are captured by a threaded metal plate behind the body sheet metal. Time and corrosion require a very focused approach to removal. The tool shown at this AMAZON location will greatly help in screw removal. I bought one and it was the best means I found when coupled with rust buster spray to remove Hudson hinge screws successfully.
https://www.amazon.com/Shake-Break-Impact-Screw-Remover/dp/B000BHJ7JM
- 182 The Flathead Forum
