Wanted 4.1 gear and pinion set for Dana rear axle
FlimFlamMan
Looking for a 4.1 gear and pinion set for a 52-54 Hudson Dana rear axle.
Thanks.
Thanks.
4.10 was standard on the Hudson build rear ends. 4.09 was standard on the Dana rear ends from 52 on. Pretty sure I have both. Could you tell me which one is the one you want?0
4.09 for the Dana, car is a 53 Super Wasp.
Thanks0 -
Well looks like a have several 4.10's Hudson built and a couple of 4.55 for a Dana but they won't help. I do have a 3.07 Dana for a 53 hydramatic if that helps.0
Appreciate you checking, I'm not wanting to go as tall as 3.07 gears.0
- 182 The Flathead Forum
