Marvel Carburetor discussion problem
Something seems to be wrong with my post regarding my Marvel Carburetors. I'm replying to comments there using quote, and they seem to be saved as a draft only when I press post comment. Over and over I keep getting the same thing. I can't even start a new comment.
So to answer a couple things. I'm using the flapper valve from the other carburetor that looks to be in fine shape.
Yes the numbers on the bottom of the carb are 10-783
Thanks Hans for the info you left me on the original post of the Marvel Carburetor rebuild. I can't seem to "quote" on any comments there anymore. When I tried to thank you for your info, I got a message in red that I was 2 characters too short to leave a comment, even though it was a full sentence. Hopefully you'll see this post.0
Power off your device and then turn it back on.0
- 118 Hudson 1916 - 1929
