What suggestions for replacement wood?
Working on the interior and needed to fix the sliding rear quarter windows on my 36T.
Although the wood frames seem intact, they appear that replacing them might be a good move.
What did they use originally and more importantly, what would be a good, easy to work with, and lasting
replacement?
Thanks!
Jeff
replacement?
Thanks!
Jeff
Wood?? Mine are metal with a painted wood grain effect. 1936 was the first year the entire body was made of metal ...no wood anywhere0
Alder. easy to machine. stable. I know companies that reproduce wood framed car bodies, and that is what they use.0
Hey Ken , yes my interior garnish moldings are metal. This is the frame that the rear quarter windows fit into. And they are wood. So it the rear header and the front header panels over the windshield and rear windows.
car mfg’s in the states used ash.
regards, Tom0 -
Thanks for the information..forgot our Hudson's had an Australian body which is similar to the USA but obviously metal rather than wood cheers ken0
I guess in Washington State, its prone to either rust or rot!
Is Ash a relatively easy wood to work with and holds up well?
Should it be sealed before installed, and if so, with what?
Thanks!
Jeff0 -
Ash is a relatively hard wood, but unlike any of the oaks (white or red) it does not splinter when subjected to shocks (think baseball bats) hickory would also be a good choice. Ash machines and shapes well.
Yes, seal it before you attach the sheet metal.
regards, Tom0 -
Thanks Tom!0
Jeff, I’m going to bookmark all your discussions since I’m following in your footsteps, literally!
jeremiah
im using ash for the sides and header on my 29 super six and white oak for the bows
Thank you trumpet79!
- 118 Hudson 1916 - 1929
