Intake valve Hudson 8 1934
Great work but expensive fee for Belgium.Once arrived in Belgium any room has a customs tax of 36 euros....BigSky said:You may want to really think about making or buying a magnetic drain plug.See this thread if you want to buy one:
https://openforum.hetclub.org/discussion/172787/hudson-magnetic-drain-plug-custom-made
Cleaning done
advancement
sanding
Dalle cooper
Drilling of the goujeons breaks
In what condition is the water jacket and radiator?I am surprised the mice have not shredded the interior.
nice find!!!
regards, Tom0 -
Waterjacket in medium condition. I found a real waterjacket quaziment new. Thank you usa. Otherwise;the water chambers around the cylinders;hours to scratch with a hook;to blow but it became impeccable again. The radiator looks beautiful;very few km the survivor 32.857 MILES.Je will have it cleaned and put under pressure.tigermoth said:In what condition is the water jacket and radiator?I am surprised the mice have not shredded the interior.
nice find!!!
regards, Tom
Collector sandblasting. High temperature epoxy paint bi component.
Axleflex
Jack can you share more photos of the head? I’ve seen heads like yours before but only on other European Hudson’s. What I’ve seen in the U.S. all the heads are flat on the top.Does anyone know the purpose for the different heads?0
The water pump is mounted to the cylinder head on these.BigSky said:Jack can you share more photos of the head? I’ve seen heads like yours before but only on other European Hudson’s. What I’ve seen in the U.S. all the heads are flat on the top.Does anyone know the purpose for the different heads?0 -
COLLECTEUR
Water pump original 1934.
Culasse
LED BULB
Final
NICE thanks for sharing you work and results Ken Cates0
first time to see red triangle with white background, Hudson tail light0
Thank you. On a white background; I mounted leds. Seen the electrical wiring of the time and many cars on the roads. So for security
All 34/35 Hudson’s and Terraplanes had the same water pump mounted in the head0
HUDSON 8's had 6 blade impellers, H / E 6's had 3 blade impellers.
I saw a T8 at Centrsl region meet in Findlry Ohio a couple of years ago with a similar similar shaped WP, but to my amazement it was aprox 3/4 to 1 inch shorter front to back. Never, ever seen another WP like it. The fan blades were very close to the Rad.
I had a pump there to compare.
I have also noticed that '32 T to '34 & '35 H & T waterpumps have had same bolt on patterns but later WP's had slightly larger appearing water outlets.0 -
Yes the blades of the fan not really ready for the radiator. The car was assembled in Antwerp, Belgium. At C.A.M car assembly center. It was for a question of tax. Example the glazing is marked securit Jemeppes on Belgian sambre; glazing.
Glass Belgium
In one of the articles I posted above, he indicates that already in 32 they were assembling packard and hudson by incorporating raw materials of national origin. As probably the glazing as on mine; we also talk about fabrics.
Here is an ad from Englebert Magazine from May 34 for the Terraplane,
The car turned today;not started since 1954.A historic day. Just a start to see because radiator has clean and put joints back in the carbu. She turned with the carbu and its joints of 1934.Unbelievable.The engine purrs like a cat
- 118 Hudson 1916 - 1929
