Water Pump Interchange
Hienkel429
Hello all,
My 55-56 crate engine that is in my 51 Hornet Sedan seems to have the 48-54 water pump on it. What is the difference, if any, and are they interchangable? Thanks all
Ray
Ray
The shaft is a little longer on the early pumps, and the fan hub is spaced a little deeper on the shaft. You can use either one on your engine.0
Excellent! Thank you!0
- 118 Hudson 1916 - 1929
