Wanted: Hornet throttle linkage parts
Does anybody have the throttle linkage bellcrank for a Hornet with hydramatic and single carburator? I'd like all the parts but the bellcrank is the main part I need. I'm converting my '53 from Twin-H to the single WGD. I'm in the Baltimore area.
Don't have those parts but are you going to sell the twin-h unit? If so, call me at 310 502-5335, thx. Niels0
Sorry, no. I want it for my other car. I bought one at the Orlando National and it's cracked.0
If you are looking for the throttle linkage (bellcrank) that attaches to the drivers side of the engine on the pivot stud I have that, but what about the bracket under the coil and the link between there and the WGD carb? If you don't have these items give me a call on the subject and I will see if I can locate them for you as well. Fred Connors 503-293-04610
Thanks. I've got the coil bracket. I'm getting the bellcrank from Hudzilla. I may be interested in the rod that goes from the bellcrank to the cross-shaft, or I can make one if someone will give me the dimension (hint, hint).0
Thanks! If you like you can email me your number at dwardo4@comcast.net0
Call me I will send it to you for the cost of postage - Fred Connors0
Hey Rob! I found a throttle part I think may be correct. Can you describe the part you have and tell me how long it is?0
Since we are on the subject, I have everything lined up to put Twin H on my Hornet except for the linkage. Anybody here have one or do I need to make one from scratch.0
Il Have At Least Twenty Sets Of Twin H Linkage And 30 Some Bell Cranks, Here At Vintage Coach, Fontana, Ca, Bill Albright0
