Where can I find a new fuel sending unit?
I STOCK NEW REPLACEMENT SENDING UNITS, EMAIL albrighthudsons@msn.com0
There are folks who advertise in Hemmings, etc., that they repair these sending units. Otherwise, Dennis Carpenter, Ford repro parts supplier, has one for the Fords that fits the Hudson tank and works well. As I recall, you need to go through a procedure to calibrate it, but it works fine.0
We have one NOS unit on our webstore. Check it out if it may work for you.0
I ALSO HAVE NOSR SENDING UNITS ( MADE BY DENNIS CARPENTER FOR) ( 9 YES THEY ARE THE SAME AS A HUDSON SENDING UNIT) I HAVE ONE IN MY 50 PACEMAKER CV THEY ARE $65 EACH + SHIPPING YOU JUST BEND THE ARM SHORTEN THE SHAFT TO THE CORRECT LENTH AND INSTALL IT HOOK UP THE WIRE AND AWAY YOU GO YOU CAN CONTACT ME AT HETHUDSON1957@AOL.COM REMOVE THE HET BEFORE SENDING THE EMAIL0
Any of you folks know where one can pick new duck material for heater/defroster under dash??? Mine has become real brittle from time. It is round and has wire in it . Is about 2in in diameter. Do they re pro on this stuff.
Thanks for in put.
Paul
NAPA Auto Parts should be able to supply the defroster hose you need. I purchased mine from there some years back. Just need to know the inside dameter of the hose.
JSpencer0 -
ask for vw ducting, the same size 2 inch, i believe, bill albright0
HornetSpecial wrote:Any of you folks know where one can pick new duck material for heater/defroster under dash??? Mine has become real brittle from time. It is round and has wire in it . Is about 2in in diameter. Do they re pro on this stuff.
Thanks for in put.
Paul
Jspencer is right...NAPA has them that's where I got my replacements from0
