34 Terraplane parts needed
dhutzn
I need a water jacket and W-1 Carb to finish the engine work. Tried brazing the jacket but just to much rust. Rebuilt carb would be great. I also need the vertical divider between the vent window and the primary window with the disappearing vent.
Help is appreciated.
The correct Carter W1 carburetor is a 281s. I may have a rebuildable core. Send me a pm and I’ll check over the weekend0
I'm looking for one that is already rebuilt. Thank you for your reply0
Ok. Good luck0
Think you may have better luck getting a good core and having Daytona Carb or similar rebuild it for you.
J0 -
Thank you for your advice. Any advice on my other needs?0
I contacted Daytona Carb. Tim is a great guy to deal with. Ordered a carb from them rebuilt. Thanks for the lead. VERY helpful!0
Glad to hear you found one. Here’s one of the two 281s carbs I rebuilt:
There's an eBay seller that is reproducing the Carter triangle carb tags with correct stamping sand inspection punches. It’s a nice touch.Hudson was a step above the manufacturers in 1934 choosing to put automatic choke (Carter Climatic Control) on all models except the commercial line. For the automatic choke to work optimally, you need the exhaust manifold mounted hot box and tube:
I just did yesterday!!!0
The W1, whilst original, was not a particularly good carburetor, and a more modern WA1, or Zenith, as David has used, (and myself on my Jet) is much better deal as far as performance and economy is concerned.0
- 118 Hudson 1916 - 1929
