6 volt regulator/relay
glynes
I need to find a regulator for '33 Terraplane 8. I believe it is actually a relay. Any suggestions where I can find one?
Try talking to this vendor for a new one:0
It is strictly not just a relay, but a cut-out, with conjointly wound coils, one very light gauge, and one very heavy gauge. The light gauge is connected to the generator at one end and ground the other. And the heavy gauge one is connected to the generator , and the other end to a normally open set of contact points. when the generator starts charging the relay energises, closing the points, and the output contact is connected to the battery (ammeter). When the generator stops charging, the battery starts discharging into the generator, and the reverse current causes the contacts to open.0
I has three terminals, one operates the light on the dash.0
That could be difficult to obtain. It would be easier, and better for your battery if you converted the generator to two-brush and used a proper regulator.0
Thank you.0
- 118 Hudson 1916 - 1929
