window channel install 53 Hornet sedan
Are you talking about installing the glass within the metal track? If so, I believe that I used rubber from Kgap (now Wildrick). I can’t remember what the thickness of the rubber was but I centered the rubber down the middle of the channel and used a soft faced mallet to tap the glass down into the channel.0
No, I need to install the window channels that the glass slides up and down inside the door.JC0
Thanks for your help and the pdfJC0
Vic, did you use the Wildrick bottom setting rubber with this channel. My glass fit a bit loose in this channel.
Fliptop, the bottom setting channel I used was from a local glass shop.0
okayjc0
What is the technique needed to install rear door glass? I am not having any luck.I followed the method used in the 48-54 body service manual but still cannot get the glass into the channel.Help!JC0
I wish I could help! I have to have mine installed at the local glass shop.0
HELP NEEDED, Glass Install Hudson Hornet
I continue to have difficulty installing the rear door glass in a 1953 Hudson Hornet. I have used the following reference material to attempt to achieve that goal. What I am I missing?
Hudson body service manual 1948-1954DOOR GLASS-REAR page 4
(All Models 1948 thru 1954
Except 1C, 1D, 2C, 2D and 3D)
· I measured the new glass and it is the same as the old (B/S 14x30x1/4)
· Do I need to remove/adjust the glass channel before trying to install the glass?
· I checked the Hudson Manuals Tech index for additional installation information
· Scanned the club “Open Forum” INSTRUCTIONS AND TIPS FOR IDEAS
· Checked window channel installation instructions (possible interference)
· Reviewed various on-line Hudson window install/repair comments
I am sure that I am not the only person to have encountered this issue. Any additional help would be appreciated.
Thanks for your time
JC
All, I finally was able to install my rear door windows. The window channel must be installed after the glass is already installed.JC0
Thank you for the update0
- 182 The Flathead Forum
