Anyone have a '55 - '56 Twin H Manifold I can borrow?
After looking at the differences between the early and late Twin H manifolds to use as a pattern for a new 2 x Weber manifold it appears the '55 - '56 would be a better option due to it incorporating the balance tube into the casting. I weighed both and it would save on coming up with custom external pipe components.
I will return the manifold as soon as the laser scan is complete, which would only take about a week. Any help would be appreciated.
I have at least 6 of those. I am pretty sure I can spare one. I will send you a message.
Thanks! Got what is needed!
The 55-56 intakes don't have the same bolt pattern as 48-54, where they bolt to the exhaust manifold.0
Does not matter. The new manifold design will not have an exhaust hook-up anyway.0
- 118 Hudson 1916 - 1929
