Cam Gear problems
Hi I have a 1934 Hudson 8 Cylinder I have been told on these cars the cam gear is fiber and if the gear fails the con rods can hit the cam lobe and break the block i believe this is true for 6 cylinder is it the same for the 8 cylinders ?
If this is true is there a alloy gear kit I think you would need a new crank gear as well are these available and where would i get one
Regards Ray Hudson
Regards Ray Hudson
Not true on the 8's the engine just stops. You can fit a later '41-47' pair of matched gears, preferably alloy cam gear. Paul Schuster may have them, or try Dale Cooper.0
Thank you I will just leave it be
It runs fine if it only comes to a halt with no damage I will not bother touching the cam cam gear
The motor is a little down but OK I would rather drive it a few more years then do a complete engine rebuild and do the gears then
Thanks again0 -
It may be worth cracking the timing cover off. As Geoff will tell you there are a number of things which can start as little problems & ultimately cause other damage down the line if not fixed timely. As an example, without a cam thrust washer in place not only can it run poorly but it can ruin your lifters. Hopefully Geoff can add to this as I’m not familiar with the 34’s 8 cylinder engine.0
Paradoxically, the missing thrust washer wil not make any difference to the way the engine runs, but yes, the lifters will have a wear pattern in them that is not central, and willhave to be refaced if worn (as in any engine from 1934-47 and to '52 8 cyl.) the most improtant thing si to use a high Zinc oil to minimise wear in the cams and lifters.0
I don’t know if the 34 engine is different than my 37 with reference to the thrust washer. However if it is the same as my 37’s 6cyl engine then I will disagree with Geoff on “not making any difference” on how the car runs.On my engine without the thrust washer in place the cam was moving back & forth as the engine ran, which changed the timing as the cam moved back & forth.You can see the timing mark jumping all over the place with the thrust washer missing in this video of my 37.
https://youtube.com/shorts/cA6wP8Kw3Sg0 -
Due to the longer stroke on the 6's David. When the crank and cam get out of sync the rods hit the cams. Bit like a belt breaking on a modern o.h.c. engine, where the pistons hit the valves. Got your mail package, thanks.0
