the SCREW
another question.. on the brake drums, what in the tarnations is the screw on the outside of the brake drums? barely sticks through the inside of brake drum....
another question is ; is it safe to remove the drums ? so i can sand the spokes and re varathane them.... i just want to make sure that the spokes all fall apart......
On my 29 Hudson, there is a small screw out near the edge of the drum that holds a small cover over an access hole. That hole is where you insert a feeler gauge when you adjust the brakes.0
I just figured out it might be a inspection hole to check brake pads0
Thank you 54coupe
after i posted0 -
Under no circumstances should you take the wheel spokes apart if it is not absolutely necessary. Nor should you remove the drum. If you do so then you must very carefully label each hole and spoke so that they go back in the original positions. Failure to do this will lead to the wheel most likely working loose, or being out of round. the bolts holding the drum on have been peened over on the ends, and most likely will strip or be weakened upon removal. As a piece of useless information, if you remove the spokes and try and get them back in their original positions in relation to each other the chances are 1 in 479,001,600. the chances of getting the drum back the original position is of course only 1 in 12. If you get it wrong it most likely will not be centred exactly, resulting in uneven brake pedal action.0
Look at the available FACTORY pictures, ............painted wheels0
- 184 The Flathead Forum
