Splasher Six
Smonica46
Did any of the Splasher Six Engines use the aluminium Head.
Yes indeed. the '34-'35 versions were in two pieces, top and bottom, with the top section only being alloy, and a gasket between them. From '36 onwards they were just one piece.0
Weren't the aluminum heads all high-compression heads?0
the composit heads, aluminum/"steel" were higher compression,0 -
The '32 and '33 Terraplane parts book list hi-comp heads as well.0
