Fuel Pump Leaking Oil
I noticed the other day that the fuel pump was leaking oil at the pin which goes through it. I can also wiggle it back & forth when I push on each end, not much but should that even be possible or should it be stationary. The pump was rebuild around 4 years ago, so I’m wondering what options there are to fix it?
It looks like the pin in your first photo should have some type of external snap ring on it. I am not familiar with your engine, but I am sure someone else will speak up.
Good idea & it’s actually the other side which has the washer. Last night I drove the pin partially out and did a little repair. I’ll find out later this evening how it worked out.0
