transmission adaptor comparisen
So this adapter will work with a 212, 232, 250 etc etc. Not sure Kerry what the Hudson 250 was.Or how does the bolt pattern of the 212 match up perfectly to a 308 ?? Hmmmmmmm0
I have installed a Wilcap adapter on my 308 in a step down. I have a T-5 trans and Wilcap's small starter. Came with needed spacers and pilot bearing and instructions.
Bought a used GM bell housing, new 10 1/2 clutch and throughout bearing.
All is working GREAT!0 -
Do you have a standard transmission on your car? I thought those adapters were designed for automatic transmissions only.TwinSupercharged said:I have installed a Wilcap adapter on my 308 in a step down. I have a T-5 trans and Wilcap's small starter. Came with needed spacers and pilot bearing and instructions.
JasonNC, yes the T-5 is a standard five speed transmission.0
I believe that Wilcap is the only one that makes a manual GM to Hudson adapter. Everyone else is automatic0
- 184 The Flathead Forum
