1951 Hudson Hornet 308 Charging System - Details
Alright, so I wanted to document what I did to get my charging system connected and updated. I was new to this before I did it and gathered information from all over to put it all together. Hopefully someone new will find this a little easier/central to reference. I used several posts from this very forum, as well as documents around the web .
Alternator
I've done a couple of alternator swaps in the past, so I just grabbed one I'm familiar with. I bought a GM style 12SI 78amp alternator from RockAuto. It was on closeout for $30. You can get any flavor you want though. The newer CS series are nice because they have internal fans, but to each his own. It's internally regulated, so I used one of the plethora of wiring diagrams on the web to wire it up.
Pulley
The alternator came with a smaller width belt pulley. I asked around on here and found some options. I got mine from Jegs. It was a Powermaster 1137 Generator Pulley.
Mounting
This was stressful. I didn't have any brackets from the generator, so I got the privilege of making them from scratch! I used some angle iron that I mounted to the block, and then bought a universal alternator mount to bolt to that. I used some straightedges, clamps, and good ol' eyeballs to line up the pulley. The adjuster was a bit of an issue here. The factory adjuster just didn't reach without mounting the alternator in a really weird position. I suppose I could have gotten an alternator with the tab clocked different, but I didn't know at the time. What I did was fairly simple. I took a piece of flat steel, drilled a hole for the existing adjuster bolt on the water pump. I drilled another hole for the next bolt up on the water pump. This let me install the steel as a solid, immobile piece. I drilled a third hole and installed a heim joint adjuster between this new piece and the alternator. I did have to tap the alternator tab in order to install the bolt.
Here's a good shot of the adjuster system.
If you look close, you can see the mounting bracket on top of the angle iron.
Belt
This took some trial and error. Since I had a custom setup, I couldn't use the factory belt size, and apparently I suck at measuring for a belt! I did find that the B/BX series belts fit the pulley width. Mine ended up being a B38 which is a solid belt. The BX38 is the one that looks toothed. I'm not sure if there is a big difference, 20min is long enough to call it good, right?
Wiring
Mine is very basic and crude at the moment. I have a 10ga from the alternator to the battery, a 14ga from the regulator to KeyOn power, and a 14ga from the regulator to the battery feed (a jumper, essentially). Aside from the starting system, that is the only thing connected at the moment. I will eventually loom and wire everything properly, I just haven't made it that far yet.
I hope this helps anyone looking for some info on what can be done. Obviously this means I'm converting to 12v, but just in case it's not...I'm converting everything to 12v.
I suck at taking pictures while I'm working. I get kind of caught up in the task and forget until afterwards. If anyone wants to see anything specific or has any questions, just let me know!
Alternator
Pulley
Mounting
Belt
Wiring
Great info. Thanks for sharing.
Nice job! Great idea on the adjuster as well.
Thanks!
Jeff
Thanks! I just hope it helps someone... Even if it is me 20yrs from now, lol
Ryan0
- 182 The Flathead Forum
