54 Hollywood i just picked up
pistonfarmer
I just picked up this poor 54 hollywood that was flipped onto its roof. I'm up to 3 hudson's now
Just a flesh wound. I've seen much worse.Whereabouts do you live? Possibly one of our forum members who lives nearby has been through a roof graft, and could stop by and give you some pointers!0
I’m in Washington state. I can do the work, I’m looking for a good 54 windshield frame tho to help0
You mean the steel frame or the stainless trim or botth?0
I’ll bet you could use a Porta Power and straighten it up. Looks something fell on it rather than a roll over.0
mainly the steel frame to start with, the trim pieces i could worry about later.Lance said:You mean the steel frame or the stainless trim or botth?0 -
Pistonfarmer; the windshield frame is spot welded to the cowl. The roof is welded to it. Years ago I had a crash part windshield frame that came with a convertible I purchased. I no longer have that part but it clearly identified to me that you should be able to remove a header from a sedan and it work on your car.0
That’s what I want to hear! I’ve sent out a couple messages for one. We will seeGlowplug said:Pistonfarmer; the windshield frame is spot welded to the cowl. The roof is welded to it. Years ago I had a crash part windshield frame that came with a convertible I purchased. I no longer have that part but it clearly identified to me that you should be able to remove a header from a sedan and it work on your car.0 -
So what’s with the doubled up leaf sprigs in the rear ?0
they are EXTRA HEAVY DUTY helper springs, i havent seen a setup like these on another hudson or nash.paulrhd29nz said:So what’s with the doubled up leaf sprigs in the rear ?0 -
pretty cool that it has the leather seats.0
I’ve seen those extra leaf springs before. They are installed to help cushion the car from heavy objects that fall onto it from above. Looks like they sorta worked as the damage could’a been worse. So it was worth installing them.
i sold my parts car it went to kentucky0
Now thats funny right there!supersix said:I’ve seen those extra leaf springs before. They are installed to help cushion the car from heavy objects that fall onto it from above. Looks like they sorta worked as the damage could’a been worse. So it was worth installing them.
Jeff0 -
Well if anyone has a lead on a 54 windshield frame from a parts car let me know please !0
BROWNE & SONS AUTO & TRUCK SALVAGE
1033 Spur 511
Sunset, TX 76270-7239940-393-2469
They have several 1954 Hudson Hornet sedans and will remove and ship parts0 -
made some progress pushing the roof out...
Don't stop now... You're going good.0
Progress made, move ahead with it and you will have a nice car before you know it0
- 184 The Flathead Forum
