Valve Cover Gaskets Needed
BigSky
I have an old gasket set for my 37 Hudson 212ci 6cyl engine but the cork valve cover gaskets are broken. Does anyone make a reusable gasket set or are they still cork? Is there even material available to cut some?
21st century hudson best price nice people0
You can also just go to a motor supply shop and buy a few lengths of cork sheets and cut out them by hand - plus you can use the off cuts for small gaskets - the cork and gasket paper is quite cheap - it's quite easy to make your own - not everyone can use a USA company supply ? Cheers ken0
I've made my own gaskets myself in the past; it's quite a soothing experience
I've got a set it's NORS in good shape I'd be happy to sell. 704 792 911zeroBigSky said:I have an old gasket set for my 37 Hudson 212ci 6cyl engine but the cork valve cover gaskets are broken. Does anyone make a reusable gasket set or are they still cork? Is there even material available to cut some?
Thanks guys, I found some Fel Pro Cork-Rubber 1/8” sheet & made the ones needed!0
