6 volt electric fuel pump
hudsonsplasher1
Looking for recommendations for a 6 volt fuel pump for my step down. They're lots of options on ebay.
I am a fan of the Carter (P 4259 I think) as its only a get fuel to the carb after sitting a while/backup/vapor lock pump. And the regular pump has no problem pulling fuel through it when its not on.
Jeff
Sounds like what I'm looking for,where did you buy the Carter?jjbubaboy said:I am a fan of the Carter (P 4259 I think) as its only a get fuel to the carb after sitting a while/backup/vapor lock pump. And the regular pump has no problem pulling fuel through it when its not on.
Jeff0 -
Here's a Speedway Motors link:
https://www.speedwaymotors.com/Carter-P4259-6-Volt-Electric-Fuel-Pumps,8837.html
The Carter needs a bypass. Yes, it does flow through at low demand, but I used to starve my engine out on hard pulls. I ended up installing a bypass with a check valve to make it work the way it should (see image). Many places carry the Carter: Amazon, Summit Racing, Jegs, etc.The Packard Club had a thorough discussion on this topic and led me to the check valve I needed:https://www.packardclub.org/forum/viewtopic.php?f=8&t=4511&start=100
NAPA also has one at less cost.NAPA Fuel PumpsPART #NNP B0110EReserve Online Price
(USD)$47.24 /EachWas $78.29Call Store for Availability
I use an AIRTEX E8011 on my Terraplanes and '49 Hudson Super Six. Been using them on my cars for a couple of decades.
It is 6 volt and can be used on both positive & negative earth systems.
I use it the same way as jjbubaboy and my mechanical pump has no problems in pulling the fuel through the Airtex (no by-pass needed).
You can buy an Airtex E8011 on ebay, or most Auto shops in the States.0 -
Thanks guys, much appreciated.0
gene, glen and i use napa got them from john pontius from his napa store. he gave us a great deal. i have them on 3 of my hudsons,no issues.0
Thanks Paul.2manyprojects said:gene, glen and i use napa got them from john pontius from his napa store. he gave us a great deal. i have them on 3 of my hudsons,no issues.0
- 118 Hudson 1916 - 1929
